I know, another Big Block heating up. But I was hoping I could get my setup to work with a little help. My 454 specs are in my sig.
What's not in the sig :
I'm running a serpentine belt, which runs the water pump and fan in the opposite direction, so reverse rotation pump. It also forces me to run a LONG waterpump, limiting the size of fan I can put on. It also limits my ability to get an efan in there, to PULL air. So i'm running two 12" Derale fans on the opposite side to push air. I did manage to squeeze a 15" reverse rotation flex fan and a 3/4" shroud with those rubber flaps for highway driving. 160* t-stat (also tried 180), 16 # rad cap with overflow. Rad is a speed cooling rad good for 700HP supposedly 1966 – 1967 Chevelle Aluminum Radiator 50:50 coolant with some water wetter. I'm running a Fitech with timing control, so 13.6 AFR and 16* at idle, 36* at 3000rpm and 14.2 AFR at cruise, and 36* 5000+ and 12.8 AFR on hard acceleration.
All said, I know it's not overheating. My Tahoe Daily runs at 210 all day and doesn't move. But cruising around and getting on it a bit, then getting stuck behind a slow driver, the temp gets up to 195. I think by the time I shut it down, i was up to 198 for a cruise temp this weekend. Seems high? I know it's not going to sit at 160 per my t-stat, but figured it would stay at least 20* away on an 80 degree day?
Should i move my whole shroud out around the fan? or install a ring on the shroud around the fan? I don't know which would be better. right now, the fan sits just flush with the shroud. Any other ideas welcome.
sorry, it's a driver, she's dirty...
