I recall using some 3M stuff... Small tube, gray-colored? Not sure if it was the "weatherstripping adheasive" (I know that comes in Yellow and Black)... I used it on the medalians, and never had a problem in 12 years...
The lower stainless trim strip, I recall that had "pins", so I don't recall using any adheasive...
Although I removed the original panels from the car years ago, I saved them for the purpose of saving the medallion and the ss strip. Getting them off the original panels last week was a real chore as the original adhesive (gray in color) was still holding like crazy. The ss strip was glued on also and had no pins. I ended up tearing the panel apart to get both pieces off.
The 3M weatherstrip adhesive sounds like a good idea. I have both the black and yellow.
Thanks, Wayne
Thanks, Wayne
3M also makes a clear emblem adhesive,and that is what I use on stuff like that.
I used black 3m weatherstrip glue with no probs
All but one of the interior panel trim items on my '66 had little spike tabs on the back to hold the trim in place by piercing the panel and bending over the tab.
However, one chrome strip was glued to the original panel. James Hinshaw told me that they could come either way...depending on the vendor.
He sold me a Locktite adhesive that worked perfect...and fast!
I don't remember the part number.
Give James a call...
