I have a 69 malibu that had a bench seat, that has since been removed.Bought a set of 68 buckets and plan on putting them in this weekend.
In Ground-up they sell a bench to bucket convertor, which from the picture basically looks like two sheet metal straps with bolts on each end, and one end bent up higher than the other. Has anyone used these and where do they go, across from front bolt to front bolt on the same seat,front to back under the track?
Or what I suspect, one on each seat on the inside track from front to back?I didn't check out the floor pan yet but are they all the same with bolt holes for bench or bucket?Thats probably a dumb question cause if it was you wouldn't need those straps.Also are the two outside holes usable on the outside track and I just drill and shim the inside?
Any info on this would be appercatied
Thanks Harry
Thanks Harry
