1 - 2 of 2 Posts
Could anyone supply a picture or a description of how to install the cable or wire from the driver side of the seat to the passenger side for slide adjustment? This is on a 68 SS with a Bench seat. Thanks in advance.
very easy
use a stiff wire , like a coat hanger (wire)
loop on end on the drivers side.
you should see a hole on the (lever) that moves
the seat back and forth.
then run the wire to the pas. side (release )
lever with the other hole. then loop in.
when complete,tension should be applied
to the wire in the center of the seat.
try to pull the wire to the front of the frame , and use a hog ring or wire tie,
to bend (hold ) the wire . so when you move the lever on the drivers side,the wire (cable)
will pull on the pas. side and release the track.
good luck :D VERY SIMPLE
1 - 2 of 2 Posts
