I am trying to install a steel blowproof bellhousing and block plate. The block plate will not fully seat against the block due to interference from the bolts for the rear cover. The same issue occurs if I try putting just the bellhousing on. I was told that any chevy bell will bolt to any chevy engine.
Is this an issue of just needing new bolts for the rear cover? If so, can you provide PN or link?
Also, I am noticing that the holes in the back of the oil pan do not align with any holes on the plate or bell. Are they necessary? I thought there were only the 6 bolts in the block.
