Hi guys, I have a question that I think you guys can answer. I have acquired a BB and if I have checked the correct letters it is a 402. The letters on the block are CLB. If I have decoded them correctly this motor should be a 300hp 402 from a 71 Chevelle. Do you guys come up with the same? The block also says passenger-Hi perfomance on the back where your flywheel would be. The heads are also stamped Hi-Perfomance. So, if you guys could help me figure this out it would be a great help.
Thanks guys,
1badchev
Thanks guys,
1badchev
