I'm not sure who your question was for since you didn't include a quote from anyone, nor address anyone by their name, nor by their username. So if I'm to guess that your question is for me, then I can only say that there seems to be some confusion here. Because where did I say that I broke an ARP rocker stud??? Anyway, thank you for chiming in.What cylinder head are you using that caused a ARP rocker stud to break? And was the breakage with the stud girdle?
92Camaro 🍺
Has anyone here had an ARP BRAND 7/16" rocker stud break on their BBC engine?? And if so, please explain if you were running STUD GIRDLES or not, and if you ever narrowed it down to the exact cause for the stud failure, if it wasn't merely due to running a lot of valve lift and lots of open valve spring pressure. I also would be curious to hear if you think the failure was RPM related. I'm just trying to learn as much as I can from you guys before making any more decisions for my valve train parts choices than I already have. Thanks in advance.I'm not sure who your question was for since you didn't include a quote from anyone, nor address anyone by their name, nor by their username. So if I'm to guess that your question is for me, then I can only say that there seems to be some confusion here. Because where did I say that I broke an ARP rocker stud??? Anyway, thank you for chiming in.
Ray, that^^^ is exactly what I've been thinking about. It seems to me that some shaft rocker set-ups might not offer much more stability than stud mounted rocker arms with a stud girdle. IDK if all stud girdles are created equal though. I have Crane gold girdles, ( at least they're gold in color anyway) but IDK if they're better or worse than any other girdle sets. I see that there's a pretty big price difference between various types of girdles. It seems that the "clamp-on" style tends to more expensive than the "solid" type. But again, IDK which type is better.....I think one other thing to look at here is the type of shaft rockers used. Even when I did swap to a shaft rocker it was only the Jesel Sportsman rocker which really is not that robust compared to other shaft rocker designs. You are still relying on the rocker stud hole threads to hold it all in place. The flimsy tie bar offers no support from an adjacent rocker stand as the pro series does. That is one of the benefits of a shaft rocker is tying the parts to other rockers for strength
