I just installed a 454 engine in my 70 El camino with auto trans. The engine has about 10.5 to 1 compression. Ran the engine on a test stand with a new rebuilt starter. Started engine several times.
Installed engine in car a few days ago. Cranked engine and it started. Then shut engine off. Last night I finished all the final details. Hit the key, engine cranked slowly than heard a screeching sound, turned off key, still screeched for a few seconds then stopped. Engine did not start. Looked under car, part of starter nose on the floor.
Snap ring on starter shaft is about a 1/2 inch out of groove, nothing else on shaft. I did not hook up the bracket because I couldn't get the bolt started with the Hooker headers. I can't see where the gear meshes with the flywheel because of the Headers and the Auto Trans housing. Is there a "ballpark" shimming number? Where would I get a cast iron nose I saw mentioned in this column?
Thanks, John.
Cast iron nose is for lrg flywheel manual trans,not auto trans.
Not using a factory starter brace along with having a loose starter bolt/s are 2 things that will cause an aluminum starter nose to break.
Scott
BUBA/L J,thatnks for setting me straight as i had forgotton the auto trans camn also run a 168 flexplate so the cast iron nose could be used.
In that case i would still use a cast rion nose for more strength along with the stock starter brace to eusure he doesn't end up breaking the starter mount flange off the block which is a real bad thing to have happen.
Scott
