1 - 20 of 30 Posts
I have a 66 with a BBC and looking for header input. I did a search and the Elite 68198 and Dougs came up numerous times. This is a street car that may make a blast down the track. I am concerned with header coatings because when I look around they all look like crap after a couple years. Now the elite and Dougs only come ceramic coated. I was considering non coated and painting every few years. Thanks for any input.
Appreciated.
I have been told that if you run a car lean it will ruin the coating according to Sanderson headers. Me I just paint them with POR 20 bake it on and run them. For the street 1 3/4" tube size is the best. 2" are torque killers.
I went with stainless since all coated I tried rusted after 5+years.
Reactions: 68Chevele
Appreciated.
I've got 1000 miles on my coated headers and they still look pretty good. The ceramic coating place said to polish them with mothers if they dulled.
Can't speak for fitment on a 66 but Summit brand painted 1 3/4" fit my 68 with an iron head 454 perfect, I have Patriot coated 1 7/8" on the 489 in it now that was dyno'ed with them and they still look great
My recomendation is to go with Hedman 68198. The coating helps keep under hood temps down. There is not a paint on this planet that will hold up to the heat produced by headers. The coating that comes on the headers will not last indefinately but will hold up better than anything else. After several years you can remove them and send them to Jet Hot which will give them a life time warranty. That is the best sen ario that one can hope for. A great fitting set of headers for a reasonable price and they are ceramic coated which is the best choice IMO.
I had a set of 68198 on my car. I removed them for a $2,500.00 set of Lemons headers which are very good headers but the ceramic coating is scratched to hellband back from the struggle to get them installed on my big block. Trust me when I say The 68198 headers are way easier to install.
Forgot to mention the Hedman elites come with a thicker flange and heavier gauge steel for the tubes that a lot of other brands. If I ever run into the situation where I have to remove my engine again I am goi g to remove my Lemons and reinstall my old Hedman Elites. But if I do that I will probably get them recoated after running them for 8 or 9 years the original coating is showing slight wear.
1966 Chevelle S.S
I have Hooker headers on mine, yaa they hang low but they have been on the car for over 20 years . and they are bent in at places so they fit my car lol....I pulled the engine this past year ....so I sent they back to Jet Hot and they recoated them for me ....and since Jet Hot did them before the cost was only half .
Discussion Starter · #13 ·
This is what I found poking around.
Hedman # 68198 (Made in USA)
Hooker # 2118
Doug Thorley # THY 313-C
Dougs # D313
Patriot # H8024-1
Now there are others ,however these seem to be better quality than others. I checked all over and the only ones that say Made in USA are the Hedmans! Is that true???
Do you have the Race or Pro-Tour headers? My Lemons will be delivered this week and I went with the Race version that wrap around the frame. I'm curious if I'm in for an adventure.
I've read elsewhere that if there are any fitment issues to give Dan a call and he'll fix them for you.
I have the pro tour headers. They are 2 inch. To be clear there are no fitment issues as when they are installed they clear every component on both sides. That being said they are a real pain to install. My suggestion would be to have your Chevelle on some knd of lift or elevated off the ground in some way. I had the advantage of installing them at the same time I was installing the engine ( two separate times) and cant imagine installing them with the engine on its mounts. Starter installation is a real brain scratcher also. You are in for a challenge.
maybe the race headers are different. I hope so.
Reactions: DraggedDown
Any of the speed shop headers are most likely only done on the outside and they will rust soon after you install them.The Jet Hot and other places that coat headers do both inside and outside.I think that's why they last so long without rusting.
1966 Chevelle S.S
My headers will not go in with the engine on its mounts, it has to be raised at least a few feet.....my stock starter will go in past the headers but you need a lot of patience .....
Those 1 7/8" headers are pretty nice, really HD headers.
1 - 20 of 30 Posts
