Define "high perf". (compression, cam, heads, intended usage, track times, dyno readings, etc.)
Define "edlebrock alum. intake". (performer, RPM, Victor, etc.)
Plus of course, Todd's equally important questions.
All of the above factor into the decision to block, restrict, or leave fully open.
Assuming you refer to the crossover passage, block it unless you';re using a stock bimetal coil choke.
