Need some opinions on my 496. Will be a street/strip motor in my full weight 69 chevelle. Eagle stroker kit on a .60 over 454. 049 heads with 2.19 1.88 valves aluminum not in my budget right now. Edelbrock rpm manifold with a Holley 850dp. 1 7/8 hooker headers. Compression is around 9.6 to 1 with a .039 gasket. No port work done to heads other than bigger valves. Thinking of going with a comp cams solid 260/[email protected] .629/.629 on a 110 Lsa. http://m.summitracing.com/parts/cca-11-220-4 the car is a 4 speed car close ratio muncie with 4.11 gears out back. How does this sound Anny suggestions? How much power might I be making? I'd like low 11s maybe high 10s at the track.
