I have a stock compression gen 6 bbc 454 w/ fully ported gm 390 castings 2.19/188 valves.Herbert solid flat tappet cam 300/310 [email protected] 250/260 570/595 lift 110 LSA 2500-6800 rpm.ProComp Dual plane airgap intake.A worked Mighty Demon 750carb.TH350 2800stall convertor & 4:10 rear gears.The car is a 1972 Impala roughly around 4000lbs.for street/strip use. Any estimates on hp & do you think Im going in the right direction with this setup?
