I know for a small block 1 and 6 both hit top dead center at the same time, and obviously the firing order is the same...so I figure there shouldnt be any difference. But just wanted to confirm, Is a big chevy at "true" TDC for both pistons at the same time?
In case you're wondering...I want to verify my TDC with a piston stop and degree wheel and then timing tape my balancer. I dont want to chance bending a valve with a piston stop, so I'll loosen the rockers on the cylinder Im checking.
Id prefer not to have to yank the brake booster to get the driver side valve cover off and do this....so figured Id find TDC for number 6...then just transpose that to #1.
Thanks folks.
Thanks folks.
