Hi Guys, last week there was a post about BB p/s steerig to fast. There was a reply about changeing valve in geer box and not pump. In GM parts it shows two, valves & springs. One set is in the main houseing & other is in the tower where high pressure line screws into. Which valve should be changed, also if you change the gear box should you change the flow control valve in p/s pump so the will be compatible. Sorry about long post.Thanks
BILL
BILL
