any help i engine builder and i need to make descision.
#7 is to only easy one on my combo;I have Hooker super Comps 2" on my 69 the only plug I have a problem with is #7 because of steering shaft other than that they fit good but snug
These are Hooker 2455-1 long tube headers, Had to dimple tube by right control arm and had to move proportional brake valve.I have Hooker super Comps 2" on my 69 the only plug I have a problem with is #7 because of steering shaft other than that they fit good but snug
I just bought a pair of patriots and they are much nicer than the Hookers I have. I just wished the merge collectors were as cheap as the one for a 2" pair. May have to modify the bigger ones to fit the 1 7/8" tubes.My Patriot 1 7/8ths fit real good, I did need to make a small dimple at a drv side motor mount bolt head, thick 3/8ths flange and IIRC 16 ga. steel, welded 3 bolt hole collector flange and ceramic coated under $500
these were ceramic coated?I just bought a pair of patriots and they are much nicer than the Hookers I have. I just wished the merge collectors were as cheap as the one for a 2" pair. May have to modify the bigger ones to fit the 1 7/8" tubes.
No they have the header wrap on them but that's ok I always wanted to see who much the temp will drop under the hood anyway.these were ceramic coated?
