1 - 11 of 11 Posts
hey guys need some help identifying my engine i have found D270 stamped on the rear of the block at the top where the bell housing would meet and to the left (driver rear of block) of that i found 10069886 and on the pass front of block R91142. any help would greatly be appreciated thanks
· Administrator
The code he posted (T0517ctz) in the other thread he's got on this comes back as a 70 Chevelle or Nova 402/350hp
There's other things wrong with this as the 10069886 casting number doesn't exist but could be 10068286 which is a 90/91 454.
Could be restamped to a 70 engine but why?
Would be nice to see all the casting numbers and stamps he's referred to --hint,hint.
In the engine forum ,he's asking for a recommend on an oil pump for a 454 so I'd guess he knows somethings not quite right with the #'s he giving.
· Super Moderator
1990 4 bolt short deck block.
Do a search on 286 block here and you'll find some good info.
The give away is the boss on the pass side where an early big starter would be bolted up with a brace. On these it's tapped as pipe thread for the knock sensor.
1 - 11 of 11 Posts
