Putting a gauge cluster in my '69 SS. I have a new M&H harness. Which are the wires to the battery guage? Is it the Black & Black/White with a tan connector? I hope so as I am running out of wires, If so, which goes where on the connector posts. Cannot find a drawing showing these wires as i thought I had seen a diagram at one time showing pink&brown, but this I think is for the tach. Please help as I am trying to get my dash in this weekend.
Yes the correct wire colors are black and black/white. The connector should only connect one way to the back of the gauge. You can check for correctness by turning on the headlights with the engine off. The gauge should indicate discharge. If it indicates charge the wires are backwards.
