my car has been really acting up ever since i replaced my front core support. at first when i cranked it up and tried to turn it off it would just keep running... so i replaced the battery cables and now it will turn off when i turn the key off. i have replaced the battery twice. it will kill the battery in less then a couple of hours (its a 495 cca battery and after sitting for an hour and a half with the cables hooked up it only had 28 amps). also the generator light stays on when the car is running. i've done the test light method (hook test light to negative cable with positive on the terminal and pull fuses until the light goes out.) but that didn't work....can anyone help me here??? TIA
-Jay
-Jay
