I added a an after-market air conditioning unit (Vintage Air) at the end of last summer.
The car gets hot inside even if the system is shut off. I suspected the vacuum controlled heater control valve (which keeps water from circulating) in one of the heater lines.
This is a plastic unit, which if vacuum is present, it closes the valve.
Anyway, sure enough, if I clamp off one of the lines, the air conditioning starts cooling fine.
Is it common for these things to go bad so soon? I was told that the plastic ones garbage. I was told to get a metal vacuum control valve, or put a wire controlled valve, or just put in a hose bib contraption! (only slightly exagerating)
Are the plastic ones POS, or did I just get a bad one from the get-go?
>>>Rod<<<
A.C.E.S. # 2894
Team Chevelle #115
>>>Rod<<<
A.C.E.S. # 2894
Team Chevelle #115
