1 - 9 of 9 Posts
I am just getting to the point were my 2door 307 is "drivable" but the backup lights don't come on when I put transmission in reverse, i knows bulbs work I have tested them and the fuse is ok. can't seem to locate backup light switch in manual or in wiring schem. please help.
Need more info.....Automatic? Column shift? 4 speed manual?
Respose to backup lights, looks like it was moved from colum to the floor 3 speed manual on the floor. hopefully this will help. mmmm, (in the colum?)
Originally posted by dadscar:
(in the colum?)
Probably still on top of the column under the dash with the wires. Believe Gregg has moved his to a 4-speed if I remember right. He should be back.
Yes John, I converted to a floor shift column when restoring back to a Muncie 4-speed, so my backup lite switch is mounted on my transmission shifter.
Mr. Muha might be correct...look down at the base of your steering column. If the car was originally a column shift, there may still be a switch that gets manipulated by the rotation of the outer sleeve of the column. An inner sleeve moves a pawl mounted on the bottom of the switch, and controls neutral safety & B/U lights.
Look for a pair of wires, most likely with a plastic terminal spliced onto it, attached to this switch. If your car has been hacked up over the years, converted to manual transmission on the floor, you may just want to make up a switch of your own by installing a plunger-style switch on a thin steel bracket, then mount to the back of your shifter. Reverse shifter arm will swing back and depress the switch activating your lights.
Good Luck & let us know how it works out.
thankyou guys for the input I appreciate it. I will look for switch at the base of the column but I think that making one up is probably to way to go, just did not want to have to hack into wiring harnesses ect. but gotta do what you gotta do ey, thanks again
SUCCESS, you guys are the best, I found the 2 wires with the connector spliced to them, under the dash at the base of the column. I did mount a switch with an arm on a bracket to the floor so when I engage reverse, BACKUP LIGHTS!!! Yeeee Ha. You guys are great thank you aging for the information it is greatly appreciated. This is a project that is getting off the ground and every little tip is hepful. I will most certainly be talking with every one again. Thanks Scott
Yeah BABY !!!!
1 - 9 of 9 Posts
