i can think of several things that will cause this condition, cracked dist. cap, crossed or bad plug wires, bad timing chain. i'm trying to reset my timing after replacing an intake and i can't seem to get the initial set due to it backfiring through the carb. i know i'm on TDC and the rotor is pointing to the number 1 plug position on the cap. i've plugged the vacuum line any obvious stuff i've missed? i plan on replacing the rotor and maybe the cap on this 454 w/hei.
thanks for any suggestions.
