Started my chevelle today it´s been stored for the winter. If I adjust the timing were it should be 35 degree total and 24 initial it backfires in driver side exhaust. If adjust timing to 60 degree total it stops backfiring. What can cause this? 100% sure balancer hasn´t spun, since I timing was fine when stored and distributor pointed at same direction.
Only mods is new headers.
Have a spare carb that I tried just to verify it´s not the carb. Steady vacum and shows same value as it uses
Engine is a 454 with 10:1 in comp, Brodix Race Rite rec heads, hyd roller 242 248 .600 .610 in lift, HEI with MSD al 6, Pro System 1000 hp carb.
