Not sure why but my back up lights constantly stay on. I checked the location of the switch on the shifter and its where its suppose to be. I checked the ground & it has good contact. I remove the ground and the lights will go off.
Any input would be greatly appreciated.
If the lights are on even when ignition switch is off, it's wired wrong. 12 volts ignition on one side of switch, backup lamps to other side of switch. Make sure the lamp wiring is sourced from the backup switch. If it checks out, the switch is stuck in closed position.
4-speed? Try twisting the rear collar in/on the steering column.
Thanks for posting back, glad you got it figured out! :D
