my car is somewhat dissassembled right now (no Battery or front clip) my after market shifter is missing the switches for the back up lamps and neutral saftey switch so i need to install these. my question is what color wires are the back up lamp wires and what color are the saftey switch wires? so i can hook this up right the first time. also are these the 2 wire clips at the bottom of the steering shaft top side? this is for a 67 chevelle. thanks Dave
There should be wires for the neutral safety switch. The NSS switch wires would be under the dash, top of the steering column, towards the bottom. Colors in the connector are purple and purple/white. The back-up switch connector should be next to it. Colors are pink and light green.
