On the starter, you will have the BIG cable from the battery, a 14ga purple wire on the small post next to the engine (which should still be there) and 'another' small post towards the frame. Run a 16ga yellow wire from the post towards the frame to the + side of the coil. (This provides a full +12VDC during cranking) There should also be a 'resistor' wire (white fabric covered) that goes to the + side of the coil. If the resistor wire has been removed, you will need a ballast resistor. You can get one for a '57 or so Chevy at any parts store. It would be sourced from the IGN terminal on the fuse box, then a white wire from the other side of the resistor to the + side of the coil. This provides a reduced voltage while in RUN mode.
