1 - 8 of 8 Posts
This is for a 72 chevelle.
Is there a kit sold for installing the back glass? I have looked and haven't found one.
Any help would be appreciated.
No kit required. You either set it on a bead of urathane or you roll out a thick cord of buytl tape and set the glass on it. Window channel must be clean and painted, molding clip installed first, and a couple of rubber blocks set in the bottom channel to prevent the glass from sliding done over time.
Butyl tape is evil. Urethane is a acquired skill. Test fit mouldings first. Follow package directions for primers on either butyl or urethane. Most parts stores and auto paint suppliers sell both. You may want to hire a skilled auto glass technician, but if you are skilled yourself, you can do it....
Steve O.
I need to figure out the reinstall of back glass on my 74 for when I pull it out. It seems that the factory glue has a rope in it to space the glass about a quarter inch up, and whatever they used has a timed self removal built into it. I will assume the earlier cars are similar with the spacing.
Bill
My glass was about 40% self un-installed, and leaking water into the car. With a razor it is easy to get in and I have done another 15%, but until I need it out I will not be doing more.
Would rather do it myself, but...
Is that price for labor only or parts too? Was that at their shop?
Bill
Kevin, I have always used the Butyl tape kit. I think 3/8 is the correct size. You should purchase a small can of brushable primer too. Make sure you have all the moulding retainer clips on hand too. The glass needs to be squeaky clean for best results. Good luck.
Bill that was at their shop. So far as I know, that included everything. I was having a new windshield installed at the time, and got to see his technique, and the materials used. He applied urethane from a powered caulking gun, which I assumed would be the same for the rear glass.
1 - 8 of 8 Posts
