Your diff is a 8.2 c-clip chevy rear. You can not always go by the rear cover as 8.5 and chevy 8.2 have interchanging covers. You need to go by the casting differences at the lower half of the center section and the axle tube cast collars where the tubes are pressed in. SO it is definitely a 8.2 chevy 10 bolt rear with c-clip axle retention 25 spline yoke 28 spline axle shafts.
you have 3.08 3.36 3.55 3.73 4.10 4.56 4.88 ring and pinion aftermarket gear choices.
Take care, Jim
