Automatic Column Linkage
707 6
I have had the DEVIL of a time finding the column shift linkage for a 72 Chevelle TH350. The previous owner had a floor shifter but took the shifter. I want to restore the column shifter. I need the part that hooks to tranny and the frame. I have the drop down from the column. any ideas?....thanks
Thanks ...as it turns out...the dropdown piece I have is too short I think. I need the whole kit n kaboodle. I built a 72 Chevelle about 15 years ago...and had NO trouble finding parts....now.....dang, just about impossible. I have the drive train complete short of the linkage..... I am AMAZED that none of the Chevelle catalogs carry these parts.
Scott
Gold Founding Member
1970 Chevelle Convertible & 1965 Chevelle SS Convertible
Scott,
Try True Connections - they have used parts as well - (909) 688-6040. Also pick up a copy of Hemmings news - there are lots of salvage yard and parts advertisements there.
Also browse the parts section here - you my find people parting out cars - you can e-mail them to see if they have that part.
One last thing - do a post in the wanted section - someone will probably e-mail you.
I have been able to locate lots of things thru the above.
Good Luck
Rich
70 SS - L34
Member # 442
www.chevelles.com/showroom/richr1
http://www.my70ss.com
Scott, checked my parts car - it does have the cross shaft, down rod, even the little bracket that bolts to the frame if you need it. 2 possibly minor problems - the spring and nylon bushing are missing (probably fell off in transit as motor and trans were gone - should be available from GM as these are common to newer cars) and this car had a powerglide. I suspect they will work with a T350 but don't know for sure. Someone who has switched trannies could tell you for sure. Let me know if this helps. Jim.
jim..YES..thats EXACTLY what I need. Let me know how much you want for them and I'll send you a money order.....thanks!!!!!!
Scott
