how hard is it to convert my 1970 from an auto to a 4 gear? other than changing the steering column(column mounted shifter).also does anyone know of a console that fits and looks good in a chevelle other than the original. i would love to have an original but after building the 468 BB i don't have the extra cash left. i do have a mega shifter but i think it will look silly on the floor all by itself. any suggestions?
I think my beer drinking team has a racing problem!
[This message has been edited by badboydale (edited 12-05-2001).]
Some things that will need to be done:
Steering column as you said.
Pedal assembly.
Z-bar and mounting points for it.
Clutch Linkages.
Backup light switch and wiring.
Depending on trans in it now- crossmember relocation.(could affect exhaust as could the z-bar)
Driveshaft length - again depending.
Yoke and U-joint type - depending.
Personally, I like the naked shifter on the floor look. Just a trim ring and rubber boot.
Most factory type consoles don't turn me on.
Make it the way you like it, forget what the other guys say!
http://chevelles.com/showroom/alelcaminofront.jpg
http://www.angelfire.com/al4/alcamino64/index.html
Most of the Chevelle parts sources have the repopped floorshift hump and boot/hardware stuff. I think it looks better that way than the factory stuff did. Also, a Hurst shifter with a Muncie handle spliced in looks cool.
It's not a hard swap, just a little expensive. When I did this swap I bought the whole kit from the Muscle Factory (pedals, linkage, etc.).
If I ever do it again, I'll try to find used pedals & whatever else I can. I think that would save you some bucks provided you're not in big hurry like I was.
I have a Hurst Comp Plus that's made just for a Chevelle w/console & it is a very good likeness of the Muncie handle. When I first got it I thought they were exactly the same, but upon a closer side by side comparison they're not identical but very close.
As for a console, I don't know of another that would look right. Since it's not a real necessity I'd just wait & get the right one.
Good luck, Pete
Gold Founding Member
Dont forget the 1.33" hole saw to drill through the steering column support for the clutch rod, I burnt my drill up on that one.
Ron
70 Chevelle SS396 (427)M21
66 Nova SS 327 M20
95 Z28 Convertible T56
Aces 3081, TC #54 Gold
