I have a 69 Chevelle that had a auto on the column. I changed it to auto floor shift. The floor console came with harness,I bought the other harness that goes from this to under the dash. I know that the Purple & White are the Neutral safty switch but can not find where the other two wires go. Seeing that my car did not come with a console shifter is there still a place for the two wires? The two wires are for lights on the console. Thanks for any info. badabob
What color are the two wires you are talking about?
If your car did not originally come with a console then the dash harness may not have a connector for the console. (I have seen some that did and some that did not).
There should be 4 wires (Unless it is a 4 speed).
Black - GND
Grey - Dash Lights
White - Courtesy light return (Door jamb switch's)
Orange - Courtesy light power (Fused battery power)
The grey and black wires go to the lights for the auto shift plate.
Orange and white go the the rear console light.
Hello Steve,
Thanks for your help!
One plug in is orange ,white and gray they are all in one connector. and then a connetor with 1 dark green and 1 light green wire.
My car did not come with a automatic floor shifter,it came with column automatic. So if it did not come with a place for these wires how do I wire it? Any suggestions? Thanks for your time
Bob
Hello Doug,
That sounds about right to me. It looks like I am going to have to splice into the other wires to make it all work. Thanks for your help
badabob,
On my '70, which I believe was previously a column shift also, the back up light plug was was at the base of the steering column next to the neutral safety switch plug. I just unplugged it from there and then plugged it in to the harness going to the console. Hope it works out for you.
Doug
Thanks for the Help! I will be keeping this page in my favorites. Great to have all this knowledge at a click of a button! Looking forward till spring and then it will be Let it Roll! Thanks agian!
