As I recently managed to make the topic of oil filter bypass valves difficult, thought I should ask about lifter valley oil shields. Moroso makes one for the big block with individual holes for each push rod, and GM makes one with that wedges between the heads but interferes with the intake manifold gasket unless the gasket is trimmed. Also a little concerned that the gasket will crush down to a height lower than the tabs that rest on the intake side of the cylinder head on the GM valley oil shield.
Any experiences on their value, in either style?
