I never even knew they had brake kits! I have NEVER had a problem with any summit brand products. I never shy away from them! They are always built buy a name brand and repackaged by summit.
Just make sure you get the 11" rotor sizes, the really cheap Summit stuff is 10.75 metric stuff from the 78 - 87 G-body and those brake are junk! Summit has both the 10.75 metric and the 11" single piston brakes.
The kit lists the rotors as 11".
Still seems kinda cheap seeing as it includes spindles.
The kit is around $300 cheaper that most 'budget' kits.
you could put together your own "kit" using your stock drum spindles and easily obtained parts for less than $500.
Gold Founding Member
I use the Right Stuff for all of my disc brake conversions and stainless lines. Great staff that is very knowledgeable.
The Right Stuff Detailing
465 Commerce Drive
Sunbury, OH 43074
800-405-2000
http://www.rightstuffdetailing.com/
