Don't even know if they make a high and low beam tri-bar headlight but if they do I would like to get a pair for my Elky. Where can I get these, anybody know?
Want to make your car really unique and stand out? .... Finish it!
Jeffry Bakken
ACES Memeber # 3994
TC Member # 1755
www.Jeffry72.50megs.com
67 Malibu in Wolf's
Clothing
70 Radical SS Clone
71 El Camino
72 4-door Sport Sedan
I have seen them at streetrod shops and street rod magazines... But not really cheap... I think they were somewhere around $60 each (I think, maybe they were less, but still pricey), Not including the bulbs...
Most of them probably use the replaceable bulbs, so the same tri-bar housing would be used for high and low beams, just install either high or low bulbs... that way if the bulb burns out, you just replace the bulb, not the whole assembly. Much like a newer car...
"Once you go RAT, you never go back..."
TC #1366
Tony
The Chevelle
Dual Quad 396
Side View
Jeffry72 Did you find anything out about the tri-bar headlights. I am gettting close to put headlights in, but did you find a bulb with a high and low?
