Re: Double spring,
James, we used to do this back in the day. It cut down points floating at high RPM. When electronic systems came online, I stopped. The extra spring tension wore things out quick, and was pretty rough on the distributor shaft.
Yes, There is something in the corvette literature about this, as Vince suggested. Special points that were developed just prior to the transistorized ignition or something like that...maybe points that were used with the Gen 1 transistorized ignition. Remember, that was the one that didn't use the inductor coil... Still used points as a switch, but had the external control module. I thought they were just single spring with a heavier spring rating, though.
But it has been awhile
