I'm tooling up for my quarter panel swap. Thought I'd practice some welds yesterday before I try to weld on the panel. I'm using a Lincoln 170T, and I bought 3 sheets of 22gauge at Home Depot. I'm cutting the sheets into little 3"X3" squares.
Anyway, my lap and plug welds are passable, but when I try to butt weld I blow holes more often than I'm comfortable with. If I touch the edges together, it's not so bad. If I have a .025" gap, then I can count on having holes. The trouble comes when I try to run small lengths (~1/2") of weld. If I just join the plates using a series of tack welds, I don't have any trouble.
What is the ideal gap for 22 gauge using .030" wire? Any other advice that you can give me?
Thanks!
Mike
Thanks!
Mike
