I have an 10.7, 498 with 60459 eddy's and 60213 lunati roller. My question is how much initial timing are you guys running? you thing 19 is enough? Im trying to dial it in. thanks
If you mean the 60212, I ran it in my 454 with 60459 heads. It likes as much initial as your starter could stand. It liked it so much I locked it out at 36* and she purred.
Vince the 213 is the GenIV/V version of the 623....
like Vince said give it what it likes. For mulipurpose duty I'd keep it around 36 total and do be careful of kickback. I got away with about 18 initial and all in by 2800 on the street...;)
I run a 60213 locked at 35. Have a toggle on the ign to avoid the kickback.
I run the 60213, as well. 22º initial, 32º total all in by 2800rpm. I had to make a custom MSD bushing to only allow 10º mechanical advance. Kickback has not been an issue so far.
I run a version of the 60212 that UDHarold had ground on 112 LSA in my 408 BBC. It has 049 heads with 2.19/1.88 valves and 10.25 CR. It has headers/Edlbrock AirGap with a ProSystems 950hp on top. Running 19 initial and 37 all in at 2200. It is a 4sp with 3.73 gears. It is very streetable and runs real good for a baby rat.
