Hello all. I have a 67 with stock antenna on the front right fender. I want to replace it with an antenna that can be collapsed so I can put my car cover on without having to put a hole in the cover. Anyone have and good recommendations on an antenna that mates up with a 67?
I have a 67 SS also and I just had to cut the hole in the cover like you said.
I'm sure that there is one out there somewhere
that will work but it would be a dog to install.
I hope you find one.
jr
Charlie. I removed the front fender antenne from my 66. Directly below the antenna's mounting point there is a reinforcement of the body reaching over the cowl area. Even when you make a hole in this reinformcement, there will still be little room for a collapsible antenne. I mounted mine in the rear.
Rob
