Thanks to everyone on this site that takes the time to help others with their problems.
I've had a 1970 Chevelle about 2 months now, which came originally with a 350, 2BBL, TH350. I know very little about the history of the car.
I removed the heads and found damage (oversized valves with worn valve guides) that warranted replacement. I am interested in basically obtaining stock performance, and purchased heads which were equivelant to stock with 76cc chambers and 1.50 exhaust, 1.94 intake valves.
While cleaning up the block (still installed in car) I noted the engine data stamps, including the block cast number (3914660). Much to my surprise, it seems I've got what was originally a 1968 327, from Camaro, Corvette or maybe Nova...no way to know.
I checked with the machine shop regarding the heads, and they verified that they will work with a 327--no problem.
While preparing to install heads, I thought to measure the piston stroke, just for information. I rotated the engine to bottom and measured distance to top of cylinder, then rotated to TDC and measured. I'm just using a ruler, not a caliper, so my measurement isn't PRECISE. However, I found that my piston has about 3.5" of travel.
Now looking in my manual, the main difference between a 327 and a 350 is the stroke...both have 4" bore. The (manual) stroke for a 350 is 3.48" For a 327 it is 3.25". I know that despite using a ruler, I am not off by 1.4"--which makes me wonder....
Is it possible someone put a 350 crankshaft into this 327 block, thereby increasing displacement to 350 cu in?? If that is possible, then it seems that is what they've done.
So this leads to my question--sorry for all the preliminaries--
I'm looking for a camshaft, something close to stock (which for a 350 in my car was valve lift of about .390" for intake, .41" for exhaust).
I am concerned about valve/piston clearance. It seems that when my pistons are at TDC they are about 1/32" from the top of the cylinder. Is this normal?
I'm thinking that changing the crankshaft from a 327 to a 350 this will increase travel at both the top and bottom of the cylinder bore about 1/8". If the blocks are really the same, it would mean that a 327 would have 1/8" more clearance between piston and valves due to shorter stroke.
This would perhaps account for lower compression ratio in 327? I'm not sure about that.
I just want to be sure that piston/valve clearance will be adequate with my pistons coming, basically, right to the top of the cylinder bores. (and I AM referring to the highest part of the piston--of course due to piston design shape it's not totally flat on top). My pistons do have the small crecsent grooves in them which I assume is meant to provide additional clearance.
The truth is I know very little about this, but want to be sure that a "stock" hydraulic cam, with these "stock" heads will be safe with pistons that high up in the cylinders.
Thanks VERY MUCH for any input!!
