I have run into 2 minor problems when getting ready to start the rebuilt big block. I have a 72 454 with long style water pump and brackets. First problem is I am using a oval port cast iron high rise intake manifold believe used from 65-69. When I was installing the upper alt bracket it is about 1/2 inch at most away from the water inlet for the heater hose. The correct intake for my car I believe would have the water inlet intake on top right behind the alt. The only thing I can think is trying to use a 90 degree adapter but I think that could cause a problem. 2nd problem is trying to run the lower alt bolt that goes into the through the lower bracket and into the head. Someone tapped all three head bracket holes larger than stock, so the correct bolt to fit the head will not go through the bracket or alt because the hole is to small. I am at a loss on how to fix this one, I cannot tap and heilecoil the head because It would be way to close to a waterjacket or thin it so bad in that area it would crack. The only thing I can think is mabey going to a pipe fitting with a reducer and screw that into the head that will reduce it to the correct size. Anyone have some good ideas for me because this is all I can come up with.
sorry for the trouble of my posts (I've posted three this week)
thanks,
steve
thanks,
steve
