I had checked the piston/head clearance and have .400" across the dome and .250" at the plug side of the dome (H693CP-030 and GMPP/EDE heads), no problem. Checked the static clearance of the valves at TDC. I have .180" clearance before the 2.25" valve just hits the inside of the eyebrow. By comparison, I checked the clearance with a set of 049's and a stock 2.07 valve and have .400", so I know the relief is plenty deep, just not wide enough.
I still have to harvest the rollers and balance of valvetrain from the 408 before I can check with clay, but using the cam spec data for lobe lift at an installed ICL, I am looking at interfence - or darn close. Short of disassembly, flycut,, rebalance, etc. I am thinking maybe I can use an offest dowel to move the head down about .030 or so. I haven't used these before - is this feasible???? I did check Moroso makes these in both .030 & .050 offset, .030 should be plenty. Other than maybe having to use the 1/8" thck intake gaskets, I can't see any other issues -am I missing something?
