Still chipping away at it. For 2021, my best was 9.15/145.6 (3600#) For 2022 it ran a 9.11/146.1
I think there might be just a little left in it but been fighting a carb fuel slosh issue ever since the car has been launching wheels up and got down in the 1.27-1.32 range. This Video of my new PB, you can hear the car bog off the line. This is as good as I can tune the carbs. Don't know what that bog would be worth but it has to be something. Tried everything I can think of; between 4-7psi fuel pressure, float levels, rubber vent connector hoses, etc. Some settings have been an improvement but nothing perfect and I'm done trying to make them work. This Video is one with the fuel pressure set at 7psi which I knew was the wrong way to go but had to try. It left hard off the brake and literally flooded out quickly during the wheelie, so bad it barely finished the pass down the track. I know there are carb metering blocks designed to fix this issue but they'd cost almost as much as these carbs did, so I'm done with them.
Had been thinking of going to the dark side with EFI, took the advise of a TC member and bought the Holley Terminator X Stealth 2x4500. It's throttle body injection but has the stand-alone ECU. Hopefully this will eradicate fuel issues and possibly get me my goal of an 8.99 pass on this engine and as a bonus, make the car a little more friendly around town. I'll be updating the thread I started in the EFI section with the install. Looking forward to being a laptop tuner and not having to get my hands gassy smelling
Happy 2023!!
Happy 2023!!
