I've got my Windstar fans on my '72 and was wondering since the bigger of the two fans has two speeds, I could wire up one of the speeds to turn on when the A/C is turned on (thus over riding the first fan speed...if its on at all yet).
To clarify, here are pics of the two motors.
Single speed fan
Two speed fan
Anyone done this?? Do I need to look at the wiring diagram for my Chevelle and use the A/C "triggering" wire for the stock A/C relay to trigger my fan relay? Any hints would be beneficial, especially if I'm missing something obvious here
Joe
Well Joe, I'm not an expert, but you might look into a "trinary" switch to trigger your high speed fan circuit. I think vintage air sells them. I believe (although I've never used one) this combines the high pressure switch with the fan trigger circuit.
hth
