I have a 454 that I am in the process of freshening, upgrading and would like some recommendations on a cam.
454 + .030
Speed Pro pistons with a.221 dome
781 casting # heads with 2.19/1.88 valves. Bowl ported.
Edelbrock tarantula intake.
850 Holley
Compression ratio about 10-1.
Headers
Cam I am now running is a Crane 272, with 272 degrees of advertised duration and .515 lift
Duration @.050 is 216
I took the motor apart to install ARP rod bolts and freshened up with new bearings and rings. The heads are at a shop having the larger valves and port work done. The car is mostly street driven with some street legal drag racing at the local strip. Thanks, Jerry
454 + .030
850 Holley
Headers
