Yes, however the radiator sits in the rubber cushions.Philip on the 67 the radiator frame bolts directly to the core support. That sbould be fine right? Im running antifreeze and have a anode. Jim
Should be if there is some bare metal between the radiator mount and the core support and the core support has a good ground to the battery.Philip on the 67 the radiator frame bolts directly to the core support. That sbould be fine right? Im running antifreeze and have a anode. Jim
