1 - 2 of 2 Posts
Hello again. I need more help with my wiring. My blinkers work even when the key is not on. Also, when I turn my left blinker on it works fine, but when I turn my right blinker on they both flash. The right one is still brighter but they both blink. I'm sure it is a ground problem but could someone tell me where to check for the solution. Thanks a lot.
Jeremy
Sort of interesting that they work without the key. Wonder if they are getting power from the hazard circuit. Do the hazard flashers work OK?
On the turn signal problem, I'll guess at a problem with the right rear bulb, only because it's making the left one light up. The thing I try is:
Turn on the right flasher (left one screwing up). While it is still flashing do the following.
Take a piece of wire. Touch one end to the lamp bulb base right where it meets the glass. Touch the other end to a known good ground. See if the left stops flashing. If so, bad ground or bad socket on the right side. If it doesn't change anything try the left.
1 - 2 of 2 Posts
