-Need to reuse intake carb for now
Cannot stroke and buy new Heads...stroking vs cost of new heads pretty close. If the better 350 got me what I wanted Im looking at maybe $800 to get it back together.
Currently...
350 with 230cc head
10:1 6" rod
Stick
4.11
26" d.radial
Currently SR cam with 250 int 670 on a 110
Will keep Team G and port for now til I can afford something better
750 DP holley
With reusing current heads
-Same motor with 11:1 compression
-11:1 with [email protected] 6xx lift 106 lsa
-11:1 383 with either cam
-11:1 396 with either cam?
OR
11:1 350 with AFR 210 comp port head
Not too concerned with manners, want to feel some power between 3-3500 meaning starting to come on but at 4k want a HARD pull to 7k+-
Realize running a stroker up that high may not be ideal
Money IS an object but dont want to put it back together and be "slightly better"...hard to tell what it was supposed to run like being as the intake was sucking oil from the gasket and the pusrods flexing like crazy.
Will check to see where the cam currently is degreed. Hate to buy a cam if I have to but if I have to then so be it.
6500 comes awful quick so keep that in mind. Will keep a solid roller.
THoughts? Power levels, Peaks?
Currently...
350 with 230cc head
10:1 6" rod
Stick
4.11
26" d.radial
750 DP holley
OR
