Sorry for the stupid question, I am new to this. I have a triple gauge from summit. It was on the car when I bought it. The needle on the amperage gauge is always at "0" never positive or negative I just had to replace the battery because the previous owner had only a 300 amp cranking battery in and it went dead from sitting. I dont want to ruin a $120 battery if there is some thing wrong. No electrical problems that I have experienced. I just notice the gauges
thanx for your help in advance
Ammeters tend to be stingy with useful info. They only tell if the system is charging or discharging (when properly connected). And they add a lot of unnecessary wiring to the car. I would suggest that you get a voltmeter and check the voltage at the battery when the car is idling. A reading of 14.5 would be good. If it is in the 12's you have a charging problem.
hate to hijack this post, but where is the best place to hook up the volt meter. Right now, mine is hooked onto what i think is a switched 12V power source for something in the dash(doesn't look like the correct readings). If at the alternator, which wire is it, and do i just run the guage in series(in line) with it?
A switched source off the fuse block should be fine. If it's not reading correct, verify it with a digital multi-meter. If your wiring is good you should be reading correct voltage on the fuse block. Don't know what wire you picked, could be a voltage drop depending on what it's connected to.
