I just converted my el camino to an HEI distributor. Hadn't done one in a while so I went on the web and got installation instructions. I coulda swore they said run a 12 gauge wire from a "battery" tap on the fuse block. Well me deciding A + B=C, I figured the battery's just a few feet away right here in the engine bay, so why not take advantage of the little pigtail coming off my non-stock positive battery cable. I mean after all it's just sittin' there going to waste. So I hook it up...fire up the motor...set the timing...dude everything's purring like a kitten so I go shut the key off...and she keeps purring like a kitten...won't shut off till I pull that direct to battery wire.
So I went to the fuse block and hooked it to an "ignition" tap...now everything's great. Starts up, runs wonderful, shuts off just like it should. I guess my question is...Am I hurting anything by tapping off an "ignition" circuit, or is that where I should have hooked it all along, and I just misunderstood or made up that whole "battery" tap off in the first place?
Skip
IGN means power when the key is "ON" while BAT means power always. You want the IGN option...
Yeah that's how I always understood it. Never had any problems hooking up radios, auxilary lights etc. Like I said... I must've THOUGHT I was following instructions (even though it didn't make sense). I obviously misunderstood and after thinking it through for myself, it all worked out.
SKIP
