I remember a few weeks ago that someone (maybe Racer1320?)was using a late model GM aluminum core/plastic tank radiator on his Chevelle. Has anyone done this? I am assuming either a late model Caprice/Impala/Roadmaster - or maybe a van? I am aware that the dimensions of a 68-72 are approx 34" x 19" overall. Just curious if someone has done the measurements.
Thanks all
Ron
Yes it was racer1320.And I haven't seen anymore on it either...I'm curious too....
Rick
66 300 Deluxe 350/330hp
71 350 malibu (project car)
72 Elcam 402SS
78 Malibu Classic (daily driver)
Here is a little tid bit I found out about radiator interchange. 68 to about 78 most GM cars had the same size radiator for instance you can take a 68 GTO radiator and put it into a 78 Bonneville. Open the cap to see how many cores the radiator is, some cars use 4 core radiator if it has a big engine and is optioned out. The 3rd generation F body car radiators will interchange with 78-87 G body cars. Some of the F body cars use the good aluminum radiators but they also use the funky plastic tanks.
As far as late model aluminum radiators are concerned, the equal face area heat transfer of a 4 row copper brass from a muscle car is the same cooling performance as a 34mm thick aluminum of equal size. Looking at the number of tubes is not a good measure. All 24, 27, and 34mm thick late model aluminums are one row of tubes. Only the 54mm used in HD trucks is 2 row. Also, it is best to refer to radiator sizes by core face area. Of course this information applies mainly to Harrison production GM radiators
70 Malibu Convertible
350/300?hp th350
I'm about to put a 402 in my '66 el camino. The radiator is 26x19. Does anyone know of a good radiator swap that will keep this motor cool? I don't mind modifying a little but I don't want to hack the core support all up.
