I've been around GM products for years, but mostly trucks- '73, '78, '84. My 1972 Chevelle has me stumped. No charge from alternator supplied w/ the car. Fine, went to parts store and bought a 55amp version for the Year/Make/Model. Still no charge, a flat 12v at fast idle w/battery charged and then somewhat discharged (11v). Figured I had a bad alternator from stock. Bench tested fine, but grabbed a different unit (bench tested good). Installed it and got 12.5v at high idle. Then my multimeter died. Took the car out and it started fine 3 times in an hour. Ammeter is no help as it was all over the place, from 6 o'clock to 10 o'clock.
Is it possible that this car has an external voltage regulator?
If so, where is the location?
I thought those Delco alternators had internal regulators...
Thank you in advance for your help.
